quick question
When I ran an SQ3500 with a Crescendo 1100.4, I had a singer 200a alt with 3 d3400's. Held mid 13's full tilt. If you're thinking of running a mids/highs amp, plus that 3.5kw amp you'll need more batts. More electrical than you need is never a bad thing.
I only plan on 1 3500.1 of something high quality and 1 4 channel amp of highish quality <---- will be a little bit on 4 channel
I only budgeting in 200 for a new battery I didn't know they were 350 plus haha. I can throw in the 50ish extra for the d3400. unless you can recommend a better one for the price. Can always add more later down road.
Im not a pro, but you should get at least 1 g31 batt.
2 of them would be much better.
Thats a pretty broad spectrum... Any specific ones? I have a yellow top agm under hood already. Is this any good?
http://www.amazon.com/Soundquest-SQB2000-Battery-High-Performance-Removable/dp/B009OGGYEM?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_2&smid=ATVPDKIKX0DER
Or This http://www.droppinhzcaraudio.com/d3400/
Or this
http://www.amazon.com/XS-Power-D1400-Battery-Terminal/dp/B005FYJ5I4/ref=sr_1_4?s=automotive&ie=UTF8&qid=1461230258&sr=1-4&keywords=xs+batteries&refinements=p_n_feature_keywords_two_browse-bin%3A7019844011
This is the battery under the hood
http://www.amazon.com/Optima-Batteries-8014-045-YellowTop-Purpose/dp/B000MSBUA4/ref=pd_sim_sbs_263_6?ie=UTF8&dpID=51k88vhwM0L&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1E47WSCFVQDWEB73HHTG
Yellow top is alright for the moment, but when me n my buddies had those they kept dying.
I run xs power now, you can get the xs power d3100 for underhood or rear.
Also the xp 3000 are good aswell but only for rear not underhood.
I ranned both before but there pricy$
When u say your runing 3500 watts, what amp are u running or planning on running?
planning on running a audio legion 3500, or a twisted sounds 3500, cresendo 3500 or a dc 3500. Whichever I can find cheaper
Umm i would really get atleast 1 xs power d3100
I finished helping a buddy of mines wire a crescendo 3500 to 2 soundqubed hdc3 18"s n he is droppin volts alot.
And he has only 1 d3100 which i sold him.
He has the amp at .5 ohm.
So if u plan on running any of those amps u stated earlier i would get 2 d3100 to be safe. Dont forget about having good quality ofc 0 gauge, probly do 2 runs.
buy good electrical first, then buy the equipment that needs it. alts and batts are your heart, the wiring your veins, and the amp your brain. your brain doesn't work as well if its only being halway supported by your heart ;)
I have 30 feet of sky high 0 ofc copper wire for big 3 redoing<-- just did it in 4 guage 2 -3 weeks ago, and 1 run to back of car for now. Plan on adding 1 battery to the back. Later plan on upgrading under hood battery. I have 250-260 to spend on battery atm. I know car audio isn't cheap haha, there is a clause to that " Good car audio" isn't cheap :D Recommend me the best battery for 260$ pretty please. I will probably use that under hood when i upgrade later to bigger back battery.
What size batt do you have under the hood now? The d3400 is 260 shipped at showtime electronics. So if u can fit it under the hood then that's right at your budget.
is battery under hood. Its 2 months old
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
