help with strapping amps
Fennygolf
hey guys havent been on here in awhile thought this would be the best place to come to get some help
im looking into 4 audiopipe apcl-1800s and im needing to know if im able to strap these amps together to run on what subs i plan on running and how i would go about doing it ive strapped amps before but it was awhile ago and dont wanna mess anything up or blow up the amps the second i play a tone
any help would be appreciated thanks guys and gals
I don't know how to strap 4 amps into one. You can take 2 amps, connect the negative outputs together. Then, the amp that is your master, you hook the rca's into and run the sync cord to the other amp. The master amp connects to the positive of your sub and the slave amp will connect to the negative of your sub. You might be confused because the only output that should be available on your slave is a positive, well that's the one you hook to the negative of your sub
  • 4 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 1737 Guests (See full list)
