Fennygolf Posted April 25, 2016 Report Share Posted April 25, 2016 hey guys havent been on here in awhile thought this would be the best place to come to get some help im looking into 4 audiopipe apcl-1800s and im needing to know if im able to strap these amps together to run on what subs i plan on running and how i would go about doing it ive strapped amps before but it was awhile ago and dont wanna mess anything up or blow up the amps the second i play a tone any help would be appreciated thanks guys and gals Link to comment Share on other sites More sharing options...
Bayuk89 Posted April 29, 2016 Report Share Posted April 29, 2016 Read the owners manual... It will tell you if its strapable and if it is it will tell you how to... Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted April 29, 2016 Report Share Posted April 29, 2016 I don't know how to strap 4 amps into one. You can take 2 amps, connect the negative outputs together. Then, the amp that is your master, you hook the rca's into and run the sync cord to the other amp. The master amp connects to the positive of your sub and the slave amp will connect to the negative of your sub. You might be confused because the only output that should be available on your slave is a positive, well that's the one you hook to the negative of your sub Link to comment Share on other sites More sharing options...
Fennygolf Posted May 28, 2016 Author Report Share Posted May 28, 2016 thanks and i yes i should have been more clear on that part i was strapping 2 together to have 2 sets my apologies Link to comment Share on other sites More sharing options...
islandpride684 Posted May 28, 2016 Report Share Posted May 28, 2016 http://www.audiopipe.com/support/manuals/car-audio/amplifiers/APCL-ClassD-Hi-P-manual.pdf In the bridging section... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
