Box tuning definition?
It will have a peak around the tuning frequency,
How well it will play above and below the tuning will depend on the enclosure design.
What exactly does box tuning mean? For example if you built a box and tuned it to 32hz does that mean it won't play below 32hz or above 32hz or is that the loudest tone it will play?
A ported box is a resonant system, the tuning frequency is where the system resonates at. Right at the tuning frequency there will be a pronounced reduction in cone excursion and if you took an impedance sweep it would be the low point with peaks on either side of it. You can play below the tuning frequency, but output will be dropping off and cone excursion will be rising quickly. In a car cabin gain will help boost how much output you get below tuning, but don't bank on getting more than a few Hz.
Box tuning is the most efficient frequency by design
[box physics nerd mode on] - At tuning most ported boxes are relatively inefficient (in terms of dB/watt), this is because the impedance is low so they are sucking in a lot of amperage/watts. The tuning frequency is often (but not always) where sensitivity (dB/volt) is very high though. Since sensitivity is usually what determines how loud our system can get with a given amp, this is a good thing.
[box physics nerd mode off]
Builds:
I was using 101 language lol
  • Who's Online   0 Members, 0 Anonymous, 907 Guests (See full list)
