99blazer Posted April 27, 2016 Report Posted April 27, 2016 My friend needs me to build him a box for Kicker Compr 12 (2016 Model). The dimensions I got to build with are 16" in height, 36" in width and 10" in depth. They recommend 1.75 to 2.25 cuft for ported. Id like to tune it 35hz but I cant seem to get the port where I need it in this space. I tried winsd and the version I have must be messed up because it is giving me very weird info like the port air velocity is at 18235.23 ms. That's with kickers recommended port size. any help on a design would be appreciated 08 Ford F150
99blazer Posted April 27, 2016 Author Report Posted April 27, 2016 here something I Came up with any advice is appreciated. What I got was 16"x36"x10" coming to 2.46 cuft then I got a port of 14.5 in height by 2" wide and 22.5" in length which brings it to 2.06 cuft with a tuning of 36hz and 14sq inches per foot on port but is 28sq inches of port enough for this box? 08 Ford F150
Triticum Agricolam Posted April 28, 2016 Report Posted April 28, 2016 How much power is going to be used? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ChevyBoy95 Posted April 28, 2016 Report Posted April 28, 2016 If you used 0.75" MDF with the max outer dimensions of 10" D x 36" W x 16" H ; With a 1.75" wide port, 14.5" tall, 23.75" long, it would give you about 1.9 cubic ft with tuning of 35/36Hz. Ports first leg would be 6.75", then the next leg going along the back wall would be 13.75" edit: this would be for running around rated power of the speaker. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
99blazer Posted April 28, 2016 Author Report Posted April 28, 2016 It would be 500watts. I played a little more last night with it. I got 16h 30w 12d with the port at 2w and 25.5l.brings the tuning right at 35 with the same amount of port area. My main concern is port noise 08 Ford F150
ChevyBoy95 Posted April 28, 2016 Report Posted April 28, 2016 It would be 500watts. I played a little more last night with it. I got 16h 30w 12d with the port at 2w and 25.5l.brings the tuning right at 35 with the same amount of port area. My main concern is port noise You won't have port noise with the port dimensions you are talking about. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
99blazer Posted April 28, 2016 Author Report Posted April 28, 2016 Do you think it needs any kind of bracing 08 Ford F150
Nightshade Posted April 28, 2016 Report Posted April 28, 2016 That box off of 500 watts should be completely fine without any bracing. Add some if you want, but it really isn't going to need any in my opinion. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
