JL W7 T Line
I am in the process of laying out the dimensions on a T line for a JL 12W7. Everything was good until trying to come to an accurate conclusion of the SD.
JL claims the SD to be; 84in2
When I measure it myself I am getting 9 in from inner surround edge to edge. Using that, 4.5 x 4.5 x 3.14 is; 63.5 in
So what gives? This is a huge difference in what the port area would be, what do I do? I would think to go from my personal measurements unless I am missing something. Help please!
Include 1/3 to half of the surround to your radius calculation and see if it gets closer.
No, what I said is just closer to the true number which is harder to measure and is usually done in a lab, I think you can just trust JL on this one.
Like Joe X said, the standard way to measure Sd is to include 1/2 a 1/3 is the surround.
Keep in mind that if you set the line area equal to Sd you will probably get a fairly significant peak in output around tuning.
Builds:
I am hoping to have a low end monster. W7 FS is 27.2 hz, that will be my tuning frequency. I have read to go slightly smaller for the line area than the SD, I haven't found an exact suggestion but was thinking around 10% less.
Thanks for the answers regarding the SD.
its also a dish not a flat plain.
That has no effect whatsoever on cone area.
I actually did measure the "dish" thinking the same thing lol but the results were very similar.
I thought I had the design set and ready to go so I could start the build log and get to jammin. But ive been reading pretty much for the last 12 hours straight on tline theory and have thoroughly confused myself. I was going to tune to the Fs because it is <30 with line length being 10.38ft. With it being a large U shape to take out any of the sharp corners/bends. My truck (single cab) is already cut for the blow through @ 16"h x 48"w, so I have got the room to do pretty much whatever here (8ft bed). But like I said, the more I read the more I don't want to do it just because I feel like its going to turn out sounding less than excellent.
Sd; 84"
Vas; 2.33ft3/66L
Fs; 27.2Hz
Could you guys steer me in the right direction here? Otherwise I've came up with a 4.5Ft3 @ 29Hz that modeled really nice. :)
  • Who's Online   0 Members, 0 Anonymous, 3876 Guests (See full list)
