zanekeimigdesigns Posted May 3, 2016 Report Posted May 3, 2016 This may have been asked before but why is it that you have to have a charger specifically for agm and gel batteries but your vehicles alternator charges all battery types? Is it just the difference between a/c and d/c charging?
ShadeTreeMechanic Posted May 3, 2016 Report Posted May 3, 2016 The alt won't correctly charge an AGM or gel cell. Here is the deal. When a lead acid battery is charged it gives off hydrogen gas. The deeper the battery was discharged, the more it will gas especially at a high rate of charge (now imagine a 250A alt). The AC charger with an AGM / gel mode tapers the rate of charge as it reaches capacity to prevent more gas from being formed than the glass mat or gel can absorb. Too much gas would cause the case to balloon and possibly leak. If you see an AGM case that looks all sucked in, its because the case vented and now it can get any air back in. If your AGM appears to have moisture on or around it that just won't seem to evaporate, its because its acid. Most of the time we can get away with an AGM on an alt because we don't usually deep discharge them and they tend to stay topped up. Guys with lots of batteries usually use a plug in onboard charger to top them up and keep them happy. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Broke_Audio_Addict Posted May 3, 2016 Report Posted May 3, 2016 A charger that plugs into your wall is still charging the battery with dc voltage. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
