secondary battery, diode isolator, am I going to burn it down?
Using an 8awg wire instead of 1/0 you will quickly find out that you won't be able to keep a fuse in it. The amp is going to try to take what ever it wants and you can't stop it. The only thing you can do is turn the volume down.
Pioneer 80PRS
And the bad thing about that is if all of it is running off of the secondary battery, he won't know that the fuse has popped until it drains the battery down below amplifier operating voltage.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
= FRIED AMP INTERNALS ... I tried to explain the situation to him but seems he doesn't want to listen, or work way harder than smarter lol. Ive given my input, I am moving along now lol.
But What Do I Know?
2003 Chevy Monte Carlo SS 3.8
  • JVC KD-R975BTS
  • Clarion EQS746
  • Kenwood P907PS
  • Ascendant Audio 12" Havoc v.1
  • Ampere Audio 2000.1
  • MB Quart Onyx 800.4
  • XS Power D3400 - Hood
  • XS Power D975 - Trunk
  • Singer 240A
  • Sky High OFC 0 & 4 gauge
  • Kno Knoise Kolossus Deadener
Maybe he has the right idea now. I know I have been out in left field with a new idea before and someone has always pulled be back in. Its hard being a Newby! lol
Maybe he will post pictures of his build.
Pioneer 80PRS
That's exactly what I thought too.
But this is the diagram: http://www.hellroaring.com/Basic%20Aux%20Audio.php
This is the instruction guide, but yeah, the wire in conjunction with the isolation device limits the throughput, without burning it off as heat.
I don't understand how this works. Think that it is able to do what it says without popping that fuse?
1995 Subaru Impreza Wagon
140A semi-HO alt upgrade
Sony GS810-BT
Hertz HDP.4 120w RMS x 4 @ 4 Ohms
German Maestro 2-way AC6511 - front door
Kicker 2-way 6.5" - rear towers
Rockford Fosgate T1500-bdCP
2x 12" Alpine Type-R parallel @ 2 Ohms - sealed box
Do you not get what we are telling you?
Here let me tell you again, it's a horrible fucking idea.
Well....... if the fuse doesn't pop then that means the amp won't get enough and it will fry when the battery voltage sags. You need more than 60a to do what you are doing. It has to come from somewhere. You would really be better off with a smaller amp. Or run what you have and turn it down a little when the needle on the volt meter starts bouncing or the lights start dimming. A battery with 60a charge isn't going to cut it. That's the point.
Pioneer 80PRS
so, you can run an isolator if you like, but your car isnt a boat. That is what isolators are for, like boats in the middle of a lake with a starting battery and a battery for accesories. You dont want a dead battery in the middle of a 500 acre lake.
So, go look through every build log here and any other car audio forum and i bet you wont see any isolators.
Te reason for that is they are a horrible idea.
But, go ahead and buy an isolator.
Ok, so no isolator then!
I definitely understand that you don't want the voltage to drop as it will cause damage. But, audio can run off the batteries when the car is off, right? I'm imagining it like that, except that I'm "trickle" charging the battery while playing music with the 60A. It won't last forever, but it'd last longer than just a battery being drained quickly. Just monitor the voltage of the batteries and turn it down/off before the voltage levels get too low and cause damage.
Like a dam/river.
-a steady river (60A from alternator) flows into a lake (the secondary battery)
-the hydroelectric dam all of a sudden gets huge demands (the music is bumping) and opens up all the waterways
-when there isn't a huge load (music isn't loud), the dam closes (power isn't being supplied to amps) and the lake gets to refill just a bit (battery charges a little)
-regardless of how fast the lake is emptied, the river doesn't flow any faster (alt never has a load greater than 60A)
-after long enough period, the lake could run dry (dead battery), but by getting a big enough lake (large batteries) and monitoring the lake water levels (battery voltage), I could turn down the demand before it reached the point where damage can occur to any part of the system.
Sony GS810-BT
  • Who's Online   0 Members, 0 Anonymous, 1475 Guests (See full list)
