Went active and now it sounds like AM radio
another thing you can try is in the network settings go to "gain" or "level" whatever it was and adjust down the mid level. Might help.
You sure your tweeters are working? you didnt hook up mid and tweet backward of the headunit right?
sorrry, might seem like dumb questions. Just trying to eliminate things.
Yes the amps are set to all pass. EQ is flat and no bass boost.
Is this headunit a bad substitution for a DSP?
Every headunit is a bad DSP solution. I've got a 2x4 MiniDSP with the advanced 2 way plugin, here's my corrected response graph after a good bit of tuning. Not even flagship headunits have the same level of performance as a $120 DSP. Going active without intense cabin prep/alteration or a big kahuna processor will leave you unhappy 10 times out of 10.
Don't trust a shop but you personally just smoked two decks, makes sense.
03' Trailblazer LT
Dayton Designer 6.5"s & Silkie tweeters
Dayton Audio Ultimax 18"
Pioneer 9601 & 8604
XS Power D3400
2 runs 1/0
Singer 250
I went active recently, with a mini dsp 2x4 : one pair of my old Focal tweeters an a pair os Seas mids. It sounded good the first time !
I have only set the crossovers. I did not play with time alignement yet.
Something must be wrong in your system. It seems like your tweeters are not playing as they should.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
The balance works properly and you are able to isolate each speaker. The tweeters sound pretty good actually but the mids sound like the bass is flat and vocals are not especially clear.
I did try setting the gains with a dmm instead of by ear so I'll turn it down on the mids and see if it helps.
When I put in my T2 components in a couple weeks, will it be worth it to buy a mini dsp or use the massive crossovers that they come with?
What does the manufacturer recommend for the tweeter lowest range? I would start with that as a point between tweeter and mid.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Infinity only states the overal frequency range of the speakers. I called them this morning and they could not reccomend any crossover points but kept reiterating that the woofer can play down to 45hz.
I am going to switch back to passive for now so it sounds decent.
Last question, when I install the t2's (rated at 100 rms) would it be better to run:
1) Jl a4300 @ 70 rms ( not over powering)
2) jl a4300 bridged @ 150rms
3) my currently installed RF punch 400.4 bridged @ 200 rms
Any one of the amps better than the other sound quality wise?
  • Who's Online   1 Member, 0 Anonymous, 1218 Guests (See full list)
