Is this voltage drop due to wire length?
How did you secure your terminals to the wire? Solder? Crimp? If crimped, what type of crimp? Your terminals will cause more drop if its a bad connection than the resistance of the wire will. Just some food for thought..
And no, the lack of a rear battery shouldnt cause a 1v loss. You've got resistance somewhere, and I'm betting it's your wire terminal/lug connecting it to the battery.
Not having a battery in the back would not be the cause. But it would alleviate the problem. The voltage drop would be a result of the wire and the connections being too small, or a bad connection. I have seen connections that look good but are not. The only way to find them is to measure the voltage across the connection under load.
Pioneer 80PRS
I soldered the terminals to the wire, and I had made sure it was done preperly. Before I shrink wrapped them, you could take the sleeve of the wire, and pull it or move it so you can see the wire. And you could see solder melted through the wire, as well as onto the terminal.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
What's the connection at your battery look like? Where the terminal makes contact with the battery post.
14v. All wires are done with 1/0 shca with shca terminals, all soldered the exact same way, so there is no physical difference between the runs tot he back, and the power and ground off the alt.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
That sounds good but if you want to know where your voltage is going then you have to measure across each connection to find it.
Pioneer 80PRS
You mean measure voltage on every single wire? Don't you read voltage by having a positive and ground? So how would you go about measuring the voltage of just a single wire, that is either a positive or ground.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
I meant what does the connection to the battery LOOK like. Not what does the voltage read. Is there any corrosion on/beneath the terminal?
Nope, even cleaned off the posts before I put new terminals on, wiped it down, scrubbed it and everything to remove and dirt and dust on them.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 935 Guests (See full list)
