MOHpro Posted June 7, 2016 Report Share Posted June 7, 2016 I have 2 questions. Before I ask the questions, yes....I had all the head unit and amplifier settings on the appropriate levels before using the DD1 to detect distortion on the HU and set the gains on my amplifiers. My HU is Kenwood DNN992. I have 2 NVX 1200.1 amps and 1 NVX 800.4 amp. The HU pre-outs are 5V. I tested all RCAs and they read about 5.28V when the HU was at maximum undistorted volume. This is a lengthy post, but I know the more details the better. Thanks for any help. Here are my 2 questions... 1.) On the 4 channel amp, when setting the gain, the gain knob was turned about a little less than a 1/4 turn, then the distortion light on the DD1 came on a bright solid red, and stayed on if i turned the gain knob up anymore, so i backed it down to the point where the distortion light goes out. Gain set no problem. On my subwoofer amplifiers, when setting the gain, i would get the usual dim quick blinks of the distortion light as i turned the gain up. When i got to about the 3/4 point on the gain knob on my subwoofer amplifiers, the distortion light on the DD1 came on a bright solid red and stayed on for a good solid second or 2 then went out. I then continued turning the gain up, and there were no more quick blinks of the distortion light from the 3/4 point to the all the way up point, and the light never came back on solid either from the 3/4 to all the way up point. I used track 5, 40hz -10db. Out of curiousity, i used track 3 and i was also able to turn up the gain all the way without the distortion light staying lit, but with the solid one or two seconds of the light staying on before going out, and with track 3 this happened a little before the 3/4 point, which was where this happened when using track 5. What should I do, stop at the point where the light stays solid for a couple seconds then goes out, or turn the gain all the way up, since the distortion lihht does not come on when the gain is all the way up. Also, since the 4 channel amp and the subwoofer amps are all the same brand and series, all with the same voltage range on the gain knob, and all RCAs are getting 5V, shouldnt the gain of the subwoofer amps be right about where it is on the 4 channel amp? 2.) Should the AC voltage at the speaker outputs on the amplifiers match the voltage of the RCAs? My RCAs read about 5.28V AC, so is this what my speaker outputs on the amplifiers should read? If not, what should the speaker outputs voltage be? Link to comment Share on other sites More sharing options...
MOHpro Posted June 7, 2016 Author Report Share Posted June 7, 2016 I will make a youtube video of this tomorrow and post the link here to better show what I am talking about Link to comment Share on other sites More sharing options...
MrSkippyJ Posted June 8, 2016 Report Share Posted June 8, 2016 Someone else can probably help with the light issue. But no, the output of your amp will not be the same voltage as the RCA voltage, it should be higher. Also no, the gain position won't be the same between your sub and 4 channel amps. The gain position might not even be the same between your sub amps. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Bryan Feltner Posted June 14, 2016 Report Share Posted June 14, 2016 Wouldn't the voltage be the same if the gain is all the way down? I know I've seen this on my amps with the gain all the way down. I have a Pioneer avh-4800 And with the gain all the way down it shows right at or just a bit over 4 volts at the speaker outputs on my amp. Then when adjusting the amp it climbs very fast and has very Little adjustment before jumping quite a bit. At one point on my amp, just over a quarter of gain, it goes up past 75 volts which in my calculations puts the amp way over rated Power and I know that can't be right. Has to be clipping at that point. Link to comment Share on other sites More sharing options...
audiofanaticz Posted June 14, 2016 Report Share Posted June 14, 2016 The amplifier is amplifying the rca voltage, so it will always vary from the radio rca output voltage even if the amplifier gain is turned down.. It could be 10.45 volts with a radio with 3.5 volt preouts, it could be 14.60 volts with a radio that has 5volt preouts. Not to mention each amp will be different (even amps of the same make and model can be different). Link to comment Share on other sites More sharing options...
