ReportDevin Posted June 20, 2016 Report Posted June 20, 2016 So I bought a new car and I knew about some of the interior problems, like the head unit constantly being on. So I decided today to get behind the dash and check out the wiring and by god this is a mess. I don't know where to start and I don't have a wiring diagram. But the HU is constantly on, and so to turn it off I just take the faceplate off. But is there anywhere to start to find out why it's constantly getting power? Any help would be appreciated.
SkarredSierra Posted June 20, 2016 Report Posted June 20, 2016 Is it wired with an adapter that plugs into the factory harness or did they splice into the wiring?
Pioneerchuck Posted June 20, 2016 Report Posted June 20, 2016 Whoever did the install more than likely has it wired to a 12v constant instead of a switched on/off source. People who dont know any better will run the 12v (+) constant and the 12v (+) switch or ignition wire to a "hot at all times" source and this is where you get a head unit that stays on 24/7. Best bet is to clean out whatever they've done, bring the harness back to stock, then start fresh.
ReportDevin Posted June 20, 2016 Author Report Posted June 20, 2016 12v constant sounds like what might be going on. It's a jumble of wires all twisted together with end caps so I'll go in tomorrow morning and try and mess with it. Busy under the hood right tonight.Now that I look at the picture it doesn't seem tooo bad. But it bugs me when half the wires are red.
SnowDrifter Posted June 20, 2016 Report Posted June 20, 2016 That's giving me a brain bleed looking at itIt's been a minute since I've put a head unit in... Look as close to the radio as you can, IIRC there should be a solid yellow and a solid red wire. Solid yellow is constant 12v battery power. Solid red is switched - power when ignition is on, dead when ignition is off. Check the red one with a multi meter and make sure it doesn't have any wire strands or something lame sticking out making contact with anything else. What's year/make/model of both car and radio? I'll see if I can find any wiring diagrams for the factory so we can start making sense of all this ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
ReportDevin Posted June 20, 2016 Author Report Posted June 20, 2016 That's giving me a brain bleed looking at it It's been a minute since I've put a head unit in... Look as close to the radio as you can, IIRC there should be a solid yellow and a solid red wire. Solid yellow is constant 12v battery power. Solid red is switched - power when ignition is on, dead when ignition is off. Check the red one with a multi meter and make sure it doesn't have any wire strands or something lame sticking out making contact with anything else. What's year/make/model of both car and radio? I'll see if I can find any wiring diagrams for the factory so we can start making sense of all this 1994 Honda Civic Del Sol - Pioneer DEH-X16UB
SnowDrifter Posted June 20, 2016 Report Posted June 20, 2016 For the wiring coming out of your car: And for the radio, what I'd do is go on eBay and buy a plug for pioneer head units. From there you can connect the wires that go to the head unit to the corresponding wires coming out of your vehicle. I hate dealing with this garbage because someone was too cheap to buy a $4.99 connector ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
ReportDevin Posted June 20, 2016 Author Report Posted June 20, 2016 So according to that diagram, ACC and Constant Power aren't even connected. I'll have to figure all this out later I don't want a headache right now. Thanks for the help Snow
Pioneerchuck Posted June 20, 2016 Report Posted June 20, 2016 the plug for the radio doesn't seem to be the part you'll need. From the looks of it, they cut off the factory plug and wired directly to the factory wiring. This is what happens when someone doesnt want to pay the $10 for an adapter. You will need to obtain the factory side harness connector. As well as the adapter connector. I have both of them listed below. This is the factory side connector. This is what you should see when you pull the radio out of the vehicle. https://www.amazon.com/Metra-71-1720-Reverse-1986-1998-Vehicles/dp/B0002BG6AA/ref=pd_lpo_263_tr_t_2?ie=UTF8&refRID=BEGDQV7ZVQ74SV3PGR8W This is going to be the adapter you'll need to go from that plug ^^^ to the wiring on your new headunit. https://www.amazon.com/Stereo-Harness-Honda-wiring-installation/dp/B000KL115W All in all you'll be looking at maybe $20 after shipping to do it right. So once you have those connectors, you can follow Snow's wiring diagram that he provided for you and you should have it looking factory and nice and clean in about 20 minutes.
Rich Schenk Posted June 20, 2016 Report Posted June 20, 2016 I agree looks like they hacked the crap out of your factory harness. First thing I would do buy new factory harness and ditch those wire nuts. Looks like a fire hazard. Get new hu harness too solder and heat shrink everything the way it's supposed to be and you should be good if you still have a issue with acc run a new wire from ignition harness just fuse the the wire. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
