Box design for RF T2D415
sTp
Hi guys i am looking for a box design for a RF T2D415 will be powered from a T1000-1bdcp main music i listen to is Drum and Bass and decaf want it to be able to play the lows if possible.
Hear are my max dimensions: Height = 45cm Width = 104cm Depth = 43cm
i Have worked out the volume of the box is around 5.50 cuft if the box needs to be made smaller shrink the width if possible.
I've seen them take a 2500cp
3 cuft with a 50-70" port area tuned to 33-35hz would be my suggestion on the 2500. I'd aim for 33hz and if I felt like the box was to big for how much power it's getting add some wood on the box and drop the volume to 2.75 tuning would still be under 35hz
I'm going to be doing 2 of them on a 1500bdcp each. 3.5cu each with 120" of port area tuned to 34hz.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I hinted around the box volume you would want.
If on more power you would want around 2.75-3 then on less power you need a ---- box
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   1 Member, 0 Anonymous, 743 Guests (See full list)
