New To The Forum
n2deep
That Would Help Me Out A lot,,,,,,,,,,,,,,,,Thanks I can cut it out and build the box , do I need to do subs on one side and port out the other side are port out the top ,, I just don't no , I was thinking of running 2-10''subs are 4-8''subs but I am not sure whats going to work the best,,
welcome to SMD
Here's a box sketch for the drivers you asked for, if you decided on these drivers let me know to give you a more detailed sketch with the needed bracing details:
Ports are 4" in diameter and 20.5" in length, box specs as before 2.5 net@ 34Hz.
Joe X ... Would i be better off with 2-10'' are 4-8'' subs in the room that I have to work with,,,,,,,, the box you posted looks good ,, I am just trying to get the most out of this Reg Cab without braking the bank,LOL
You could 3 8" subs in about the same space but less subs is less expensive and even number of subs is better impedance match to the amp so I would recommend to use two 10s but with better power handling, say if your amp is 1000 watt rms then get two 500W 10" subs, from skar maybe the VD series or the ivx v2 series would work fine with that amp and it looks they are pretty inexpensive.
The amps I have are hand me downs from my Dad he run them long time ago, still 100% working, , I Am going to go with 2-10''subs I am looking for a good deal on some now, but looks like Skar Audio has the best deal going right now on the IVX-V2 So I just put in my order for 2 of them ,,, The box you posted will be what I will be running them in,,,
Do I need a 3/4'' Round over on the port side of the box,,, and what do I need on the inside of the box,,,
Here's something for the two IVXv2 10s:
It uses a single 6" round port 18 1/4" long, box spec is 2.9 net @34Hz. there should be 6" port clearance available, make sure it's the case.
  • Who's Online   0 Members, 0 Anonymous, 4551 Guests (See full list)
