feathered1iron Posted July 18, 2016 Report Posted July 18, 2016 Hey guys, Just received a DG motorsports roll pan for my 06 escalade ext. I would like to upgrade the license plate lights while I'm at it. I am assuming the stock ones are halogen? 1.) If I went with LED or HID lights would I need to replace the entire wiring or do they make like an adapater kit? 2.) Should I just got with some look a like HID's if I am unable to replace the harness? Any info would be great, lighting newb and didn't know which section to post this in. Thanks as always for ANY information!! Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
feathered1iron Posted July 18, 2016 Author Report Posted July 18, 2016 Gunnem, thanks! Would I need to buy a kit that comes with a new wiring harness or would it plug and play? Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
Broke_Audio_Addict Posted July 18, 2016 Report Posted July 18, 2016 The stock ones are incandescent, Leds will be fine and no you don't need a special wiring harness. You may however need canbus type bulbs. I don't even think there is such a thing as hid licence plate lights, and if there is there shouldn't be. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
feathered1iron Posted July 18, 2016 Author Report Posted July 18, 2016 Thanks guys, so just get an led bulb. Any recomendations on a specific company Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
feathered1iron Posted July 19, 2016 Author Report Posted July 19, 2016 Anyone? Current Setup: Mechman 370a Alt 4 pin DC Triple Alt Bracket XS3400 Battery 4 Ampere 6.5 components 4 tweets Ampere 150.4 way Norcal SS Custom 3/5 Lowering Kit with 3inch Lower Control Arms DG Roll Pan LED License Plate Lights
Dan2427 Posted July 19, 2016 Report Posted July 19, 2016 I'm guessing u probably just got 194 bulbs since its GM could be wrong. But I just bought mine from a truck stop for like 8 bucks. 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
