Help needed installing amps in a 2016 Silverado
then you have to ask yourself, why now, what changed and why wont the other loc's work? something is bad and its not the loc. have you tried another amp?
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
Could be bad wiring for the stock Bose amp causing issues with that amp. Could be the Bose amp going out.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
slamming door zonks everything out, you may have a pinched speaker wire somewhere, when the output from your system causes enough vibration it causes the wire to short, possible reason the door slamming takes place,,, I just recently did a silverado, same year non bose and had all sorts of noise in the system, I ended up getting a jl clean sweep and it was money... but I noticed it was damn near impossible to grab a switched 12v power in the fuse box that would behave correctly so i ended up using the music sense remote out function of the clean sweep, if I might ask what amps are you using?
Have you tried changing sub amp and seeing what happens? Might be a fault in your amp.
interesting, is it the only at max volume? or close to max volume?
i got it.... put a multimeter on your bose subwoofer speaker wire that you have connected to your loc, make sure the meter is set to ac voltage. turn up the stereo while watching this voltage increase. see if the voltage suddenly drops or completely stops when your amp cuts off. if it does then your bose sub amp is going into protect mode. or is just faulty
ONE OTHER TROUBLE SHOOTING IDEA, TRY TO HOOK A CELL PHONE DIRECTLY UP TO YOUR SUB AMP AND SEE IF YOU CAN GET IT TO CUT OUT. COULD BE A GROUND ISSUE.
  • Who's Online   0 Members, 0 Anonymous, 984 Guests (See full list)
