jessdabest77 Posted August 1, 2016 Report Posted August 1, 2016 I'm building a cut through in a Silverado and it's going to be four 12's in a fourth order box and my question is how to make a removable back panel for it? The port will be shooting into the cabin and the back of the subs will be in the ported side. If anyone has any pictures to that be real helpful thanks guys.
Parker Grundy Posted August 1, 2016 Report Posted August 1, 2016 Like what exo did Used t-nuts in dis vid
deadbroke Posted August 9, 2016 Report Posted August 9, 2016 Those two videos are going to be about the best you would need. I just finished up the majority of my removable panels and used a combination of both of those videos. There isn't much of a deviation, from what i have researched, to installing a panel that you can remove. I would recommend t nuts or a fastener of some type for all removable panels so you don't keep chewing up the wood from the screws with removal and install. If you want to brace it i would run a stringer across the opening where you want to put the panel and place t nuts on the back of it as well to add another area of rigidity. I plan on putting a sealant between the box and panel to make it air tight so that might be something else to look into.
ShadeTreeMechanic Posted August 9, 2016 Report Posted August 9, 2016 I use caulking cord. It is soft like putty and doesn't harden. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
3vil Posted August 10, 2016 Report Posted August 10, 2016 You can find buytl rope locally at a lot of hardware stores, and it'll work for sealing overlapping panels. Also it's pretty cheap.
