sinister317 Posted August 10, 2016 Report Posted August 10, 2016 Want to install extra battery for sounds. Do I need a isolator or no? Only pushing 1600 rms but I am seeing voltage drops. It's a factory 160amp alt and agm battery. If not can I ground tha batteries separately from each other and just ground amp to second battery.
MrSkippyJ Posted August 10, 2016 Report Posted August 10, 2016 No isolator F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
sinister317 Posted August 10, 2016 Author Report Posted August 10, 2016 No isolator ok how bout the grounds does it matter? And will a stock alt handle that type of load.
Rich Schenk Posted August 10, 2016 Report Posted August 10, 2016 No isolator or relay needed hook it up in parrel On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
MrSkippyJ Posted August 10, 2016 Report Posted August 10, 2016 what do you mean by grounding the batteries separate? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
sinister317 Posted August 10, 2016 Author Report Posted August 10, 2016 I have to different locations that are factory grounds. I just want to leave the regular battery grounded where it's at and ground thee extra one at a different ground point
koolcat90 Posted August 10, 2016 Report Posted August 10, 2016 I have to different locations that are factory grounds. I just want to leave the regular battery grounded where it's at and ground thee extra one at a different ground point That would be fine. I don't believe it matters as to where you ground the 2nd AGM battery. I have mine grounded in the trunk to the same spot amp is grounded. Make sure you've sanded your grounding point so you make a good clean connection.
sinister317 Posted August 10, 2016 Author Report Posted August 10, 2016 Ok cool and I was just going to ground amp to 2nd battery if that's a ok thing to do lol.
sinister317 Posted August 10, 2016 Author Report Posted August 10, 2016 On that note does the extra battery have to be the same size as the starting battery, which is a agm also. It has 91amp hours.
Bayuk89 Posted August 11, 2016 Report Posted August 11, 2016 ^^^ im my opinion no, when adding extra batteries and wiring in parallel, your keeping 12 volts but your combining cranking amps and aH (amp hour) group 31 is a more common size to use when adding a second battery but you can use any battery group, just the bigger the battery the more capacity you will have. Its a good idea to stick will all wet cell batteries or all AGM batteries.
