jessdabest77 Posted August 11, 2016 Report Posted August 11, 2016 What amp would be ideal to run on two SA12's rev3 , a 2200 watt amp or a 3k amp? Also with one of the amps, what size box,port,and tunning? This will be on good electrical.
Joe X Posted August 11, 2016 Report Posted August 11, 2016 If you have electrical for a 3K amp I would be looking at higher end subs.
Mariothadon Posted August 11, 2016 Report Posted August 11, 2016 Either different subs or just get the 2200 watt amp I would suppose. That leaves some head room.
jessdabest77 Posted August 11, 2016 Author Report Posted August 11, 2016 Ok, if I do the 2200,what's a good size box,port,and tunning for it?
Triticum Agricolam Posted August 11, 2016 Report Posted August 11, 2016 You won't hear the difference between a 2200 watt and a 3000 watt amp anyway. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
jessdabest77 Posted August 12, 2016 Author Report Posted August 12, 2016 Ok thanks what about box specs with the power
