NoName Posted August 12, 2016 Report Posted August 12, 2016 Building my first box, going to order materials soon.But is it even worth it? I don't know if I did the right job designing it, will it work?Main problem I had, I did not know if I calculated volume corretly, do I add or remove port from volume, did my program remove it for me. Really need someones proofing, so I would not just ruin materials..Thank you in advance for your help.Here is the box: Here is sub spec:
RooTxBeeR Posted August 12, 2016 Report Posted August 12, 2016 I don't understand how you labeled the lengths of the box. In which direction are the sub and port facing from the box standing in the position it will be in your car? On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Mantvydas Strikauskis Posted August 12, 2016 Report Posted August 12, 2016 I don't understand how you labeled the lengths of the box. In which direction are the sub and port facing from the box standing in the position it will be in your car? Looking from top to bottom on the list I marked where which pannel is.
RooTxBeeR Posted August 12, 2016 Report Posted August 12, 2016 I am still having a hard time figuring out what numbers are what, which is width, depth, height. From the rough estimate I did looks like the box you put together is just under 1cuft, tuned to 35hz with 14.5sqin of port area. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
ckeeler11 Posted August 15, 2016 Report Posted August 15, 2016 I came up with a box 13" high x 26" wide x 12.8" deep. port is 1.5" x 11.5" x 28" long. net of 1.3 tuned to 33 Hz. Am i close?? if so what amp you running? port might be to small.
NoName Posted August 17, 2016 Author Report Posted August 17, 2016 Older DLS D1000 at 2 ohm. I got the wood already. Will assembly soon.
ckeeler11 Posted August 17, 2016 Report Posted August 17, 2016 i would say most definitley the port is to small on 750 watts. need to open it up some more. What is model of sub?
NoName Posted August 26, 2016 Author Report Posted August 26, 2016 Ok, so I finally made it, tested it and it sounds like disappointment :/ my 18L sealed is as loud as this box.Did rough recalculations on RE audio calc and it seemed pretty good: Did not add all the screws, wanted to get a listen to it and it turned out nothing like I aspected... Is there any way to improve on what I made?
audiofanaticz Posted August 26, 2016 Report Posted August 26, 2016 first improvement would be to not use the RE audio app, it is very off. google torres box calculator or search for it on the forum here.
Mantvydas Strikauskis Posted August 26, 2016 Report Posted August 26, 2016 To design it I used WINISD, to double check I used RE audio app.I am wondering if its posible to make it better from what I have got, I could play with the port since I did not glue it in before testing..
