Cliff Younce Posted August 14, 2016 Author Report Posted August 14, 2016 the mismatch came on a trade that i didnt even suspect a mismatch. didnt know until i built new box and found out. Still noone answered my original question.
Jessica Posted August 14, 2016 Report Posted August 14, 2016 http://www.bcae1.com/spkrmlti.htm use that, there should be a calc there that will help, just have to scroll through them. may have to use two separate ones and plug the results into another. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Cliff Younce Posted August 14, 2016 Author Report Posted August 14, 2016 the mismatch came on a trade that i didnt even suspect a mismatch. didnt know until i built new box and found out. Still noone answered my original question. sry double post.dont know why it did this
Cliff Younce Posted August 14, 2016 Author Report Posted August 14, 2016 http://www.bcae1.com/spkrmlti.htm use that, there should be a calc there that will help, just have to scroll through them. may have to use two separate ones and plug the results into another. k.thx
ShadeTreeMechanic Posted August 14, 2016 Report Posted August 14, 2016 In a series circuit, the series branch is known as a voltage divider. Voltage is divided between each load in series equally if the loads are equal. If they are not equal, the load with the highest resistance will drop the most voltage across it. In a parallel circuit known as a current divider, the current is divided at each node equally if all loads are equal. If loads are not equal, the load with the lowest resistance gets the most current. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Jessica Posted August 14, 2016 Report Posted August 14, 2016 In a series circuit, the series branch is known as a voltage divider. Voltage is divided between each load in series equally if the loads are equal. If they are not equal, the load with the highest resistance will drop the most voltage across it. In a parallel circuit known as a current divider, the current is divided at each node equally if all loads are equal. If loads are not equal, the load with the lowest resistance gets the most current. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Triticum Agricolam Posted August 14, 2016 Report Posted August 14, 2016 i am running my dual 4 parallel and my dual 2 only on one coil so they both are at 2, paralleled at amp running 1 ohm Running one sub on only one coil actually makes your problems worse. When you run a DVC sub on only one coil it significantly changes the T/S parameters of the sub. So instead of just having mismatched impedance, you have completely mismatched subs. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
MrSkippyJ Posted August 14, 2016 Report Posted August 14, 2016 In a series circuit, the series branch is known as a voltage divider. Voltage is divided between each load in series equally if the loads are equal. If they are not equal, the load with the highest resistance will drop the most voltage across it. In a parallel circuit known as a current divider, the current is divided at each node equally if all loads are equal. If loads are not equal, the load with the lowest resistance gets the most current. Thanks for the response, I was in a hurry on my phone and had to type a short question. Help me understand though, because I am electrically uneducated...it makes sense now that you explained it, but I still don't understand why. Why does the extra voltage go to the highest resistance, in my head it seems like it would go to the lowest. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
