welderblake21 Posted August 13, 2016 Report Posted August 13, 2016 Im wanting to build a wall, but I don't know if I even need to or if I will have enough room. I got a 96 z71 extended cab and wanting to do 4 xfl 15s. The entire back of the cab is free to use, it comes off the wall to the front seat 21" and it's like 49 side to side, I can't remember but it was like 40 something from floor to roof. Do I even have enough room to do this, or will I even need to for 4 of these 15s in that truck? I may just go ahead and say 6 15s if I have enough space.
n8ball2013 Posted August 13, 2016 Report Posted August 13, 2016 Yes you do. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
welderblake21 Posted August 13, 2016 Author Report Posted August 13, 2016 Would a wall be needed for 4 of them or not really
SoCaLBaMF Posted August 13, 2016 Report Posted August 13, 2016 Yes you do. But what would you know? lol 2004 Bagged Trailblazer (4)18" Sundown Nsv3s (4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4 (2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
n8ball2013 Posted August 13, 2016 Report Posted August 13, 2016 Not much. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
welderblake21 Posted August 13, 2016 Author Report Posted August 13, 2016 Will a wall be to big for 4 of them? Or should I just go with 6 of them
welderblake21 Posted August 13, 2016 Author Report Posted August 13, 2016 And is there any would that knows how to build them that could come up with some measurements. Or can someone point me in the right direction on how to figure out all that
ShadeTreeMechanic Posted August 13, 2016 Report Posted August 13, 2016 look at some of the wall builds here. Read, read and read some more. There are too many variables for someone to design this for you without problems. It also depends on the total system layout like where are the amps going to go? How much power? Where are you going to put all of your batteries? How many alternators are you going to run? And the list goes on and on. I would suggest starting smaller and build a box that comes up to the window line first. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
welderblake21 Posted August 13, 2016 Author Report Posted August 13, 2016 Well I've already got 2 15s in a custom box, I just want more. That's a good point though.
SkarredSierra Posted August 13, 2016 Report Posted August 13, 2016 You could also do 4 ct sounds 18s. The stratos are 200 each on ebay. They also have good prices on some ct sounds refurbed amps. The ct 4000.1d is only 520. Just another option.
