tbeats Posted August 16, 2016 Report Posted August 16, 2016 With a tuning of 37hz where should the ssf be set? Subs 2 sa12's in a 1.6 cubic net with a 1500 rms.
Smoove Posted August 16, 2016 Report Posted August 16, 2016 With a tuning of 37hz where should the ssf be set? Subs 2 sa12's in a 1.6 cubic net with a 1500 rms. In theory 28, but if you unload with boosted tracks start at 30 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
tbeats Posted August 16, 2016 Author Report Posted August 16, 2016 With a tuning of 37hz where should the ssf be set? Subs 2 sa12's in a 1.6 cubic net with a 1500 rms.In theory 28, but if you unload with boosted tracks start at 30so 28hz could be dangerous? That's the number I was getting. I looked at it as I'm running a smaller box I should be safer at 28hz then say I was at 2.0 cubic per sub vs the 1.6 I'm at now. I could be wrong.
Smoove Posted August 16, 2016 Report Posted August 16, 2016 With a tuning of 37hz where should the ssf be set? Subs 2 sa12's in a 1.6 cubic net with a 1500 rms.In theory 28, but if you unload with boosted tracks start at 30so 28hz could be dangerous? That's the number I was getting. I looked at it as I'm running a smaller box I should be safer at 28hz then say I was at 2.0 cubic per sub vs the 1.6 I'm at now. I could be wrong. All depends on what you playing and how clean the music is. You can't trust boosted tracks. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
Smoove Posted August 16, 2016 Report Posted August 16, 2016 ExampleI can play 19hz on a clean track without unloading22hz with a dirty track without unloadingso I'm set at 22hz just to be safe. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
tbeats Posted August 16, 2016 Author Report Posted August 16, 2016 Example I can play 19hz on a clean track without unloading 22hz with a dirty track without unloading so I'm set at 22hz just to be safe. definitely see your point. I'll try 30 then, right now I'm set at 35hz I wanted to just play around some. I only play original music no boosted or altered recordings. So maybe 28hz as a test.
Smoove Posted August 16, 2016 Report Posted August 16, 2016 Good idea, play it and test.Also a factor is stuff like cabin rise. no one can predict how it will affect pressure or rise. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
zoeboi954 Posted August 16, 2016 Report Posted August 16, 2016 Go to this forum it will teach u on how to correctly set ur ssf to the best safe settings possible its all based on your box tuning. But if u want to skip the reading ur ssf is actually 27.75 round it to 28hz thats is what you should set ur ssf http://www.stevemeadedesigns.com/board/topic/156565-how-to-set-your-subsonic-filter/ 4 Fi Q 12s In A Prius on 4 Crescendo BC2000D?! That's Absurd (!!!UNDER CONSTRUCTION!!!) go follow http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/
