sbg Posted August 24, 2016 Report Posted August 24, 2016 So I just went from a FI sp4 18 in 5cuft tuned to 37 with 80 " port area, To a 18" DSS ethos in 6cuft tuned to 32 with 88" of port. And am having a problem in a few ways , first off its like 1/2 as loud. 2nd it's making a sound like it's bottoming out. Is 6 cuft to big? Power is 2 synergy audio wfo 15.1. Clampped 4600 put out of them On the term lab last time I went to a comp 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
3vil Posted August 24, 2016 Report Posted August 24, 2016 What's your SSF set to? And have you done sweeps to figure out around what freq it's acting up?
sbg Posted August 24, 2016 Author Report Posted August 24, 2016 What's your SSF set to? And have you done sweeps to figure out around what freq it's acting up? Ssf is set to around 20hz, seems to be be around tuning that it's bottoming out. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Triticum Agricolam Posted August 24, 2016 Report Posted August 24, 2016 Around tuning its highly unlikely its bottoming out, since excursion it at a minimum around that frequency. However stress on the box is at its highest, so it might be something has come loose in your box somewhere, that's often what causes these kind of noises. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
sbg Posted August 24, 2016 Author Report Posted August 24, 2016 I was told that the 6cuft box I built for this sub is to big, that for my power and that sub it should be in 4 -4.5 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted August 24, 2016 Author Report Posted August 24, 2016 Around tuning its highly unlikely its bottoming out, since excursion it at a minimum around that frequency. However stress on the box is at its highest, so it might be something has come loose in your box somewhere, that's often what causes these kind of noises. I will have to look the box over but I'm,pretty sure it's the sub 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
ToNasty Posted August 24, 2016 Report Posted August 24, 2016 I would put the dss in the box the sp4 was is ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
sbg Posted August 24, 2016 Author Report Posted August 24, 2016 I would put the dss in the box the sp4 was is I'm going to do that tomorrow and see what it does. Its crazy for real it's like 1/2 as loud as the sp4 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
3vil Posted August 24, 2016 Report Posted August 24, 2016 You should double check the the box to make sure there isn't any loose bracing or panels. Like Triticum implied, you might have parts slapping together as the box resonates.
sbg Posted August 24, 2016 Author Report Posted August 24, 2016 You should double check the the box to make sure there isn't any loose bracing or panels. Like Triticum implied, you might have parts slapping together as the box resonates. Yep going to check today, the box has about a gal of fiberglass resin inside over all parts.from the put side the don't don't flex at all 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
