Set 2 channel amp for sundown components with the dd1.
On the sundown sa cs6.5v2 crossover it has for the tweeter +0db, -3db and +3db when using the dd1 to set gain on a rockford p300x2 should I do the tweeter on +0db? I ask because as of right now I'm set to +3db and at max volume set all with the dd1 my tweeterson will cut out dew to protect circuit.
That's for attenuation of the tweeter, it allows you to modify the tweeter output in case they at to sharp or making a little. I'd stay with it at 0dB. I feel like you should be hooking the dd1 on the amp output before the crossover when checking for distortion, but I might be wrong.
yes I have the dd1 on the amp output not on the crossover. I'm basically I guess looking at if I'm setting my gain at -5db on the amp then having the tweeter on +3db it's stressing the tweeter over power? And robbing mid bass performance from the woofer.
If your tweeters are cutting out then you are kicking their butt. The dd1 is just a reference. Different songs can be recorded at different levels and different sources can have a different level too. Ultimately it is up to the operator of the volume control.
Pioneer 80PRS
definitely but going with 0db on the crossover wouldn't that equal out the power with the woofer and help the tweeters from over working because +3db has to be over working them I believe.
Well, that tweeter attenuation is to balance the sound between the tweeter and mid. Not necessarily to keep the tweeter alive.
Pioneer 80PRS
If you want to be louder, you could add another set of tweets and mids.
Pioneer 80PRS
  • Who's Online   1 Member, 0 Anonymous, 1532 Guests (See full list)
