2009 Chevy Traverse Door Wiring
Hello gang! I am looking for a solution for a wiring problem that exists with my 2009 chevy traverse. Theses models have a common problem where if it rains the radio stops working until it drys out. This is a modular design with a non weather tight seal. Unsure why the chevy engineers thought this was a good idea but anyway.
I am going to upgrade the entire sound system in this vehicle and I am not interested in using stock wiring. what are my options?
If it's anything like my 2009 equinox, which it should be, there should be a black rubber boot on it. If the wiring and the white plug thing that connects to the pillar is exposed, someone at some point cut the boot off. Pictures will help.
I had water leaking in my truck from that boot. It took me a while to figure out and the boot is fucked. I used the black sealant for a water pump to cover it up and it's been fine
I have tried with zero success to figure out why or where the water intrusion is coming from. After a day or 2 of no rain all the speakers work. Rain and then they dont work. The power windows work when speakers dont so maybe a voltage thing? Power window motor draws more power and works thru it? I personally would just like to find a solution to run a dedicated speaker wire to new components.
if there's room, install a traditional boot above or below the current one. Might have to take the door off to drill the holes but the stupid modular connector makes that easy haha.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
