cvanwey Posted September 8, 2016 Report Posted September 8, 2016 Here's the scenario.... Car: Mercedes CLA 45 AMG <- rear seats can fold down, but I won't '-) Sub amp: Zapco C2K 9.0 (4 ohm version) Electrical: 175A alt. and 80AH AGM battery Music: Speed metal (lots of double bass) Space allowed: Up to 3.0^ft net Goal: Want the kick drum to take my soul (throb)! Here's the subs I have.... (1) Digital Designs DD9512f (2) Sundown SA-10's ________________________________ Currently, I have the DD in there, as I already had it in a box from the previous car. It is 1.9^ft net tuned to 40 htz. Sub and port are rear firing. Sounds great, just wondering if redoing anything new will benefit or not??????? Would I be more satisfied to rebuild the box and keep the DD in there w/ different specs. Or, do the Sundown 10's instead?.?.? Thanks!
Triticum Agricolam Posted September 8, 2016 Report Posted September 8, 2016 Are you happy with the amount of output you are currently getting? What aspect of your system would you like to improve? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ShadeTreeMechanic Posted September 8, 2016 Report Posted September 8, 2016 Maybe try tuning to 45 or 50hz. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
cvanwey Posted September 9, 2016 Author Report Posted September 9, 2016 Are you happy with the amount of output you are currently getting? What aspect of your system would you like to improve? Let me rephrase my OP. What's going to provide more output, most likely, the (1) DD9512 or the (2) SA-10's? On the one hand, the 2 10's have more cone area (but 1000 watts X 2). On the other hand, the motor of the 12 is much stronger (2000 X 1). Basically, both setups will have the ability to roughly reach their peak performances. Yes, I know they may be able to take more.... I guess I'm asking, would it be worth my while to put the 2 10's in there, or just leave the 12 and tweak it? It sounds really good now, just want to know if there would be an audible difference going to 10's? I will more than likely not keep the woofers I don't use, and I don't want to spend the time to build a nice box for subs I will not use ;-) This is why I ask the experts here. Thanks!
audiofanaticz Posted September 9, 2016 Report Posted September 9, 2016 No versus threads. no one can tell you which will have more output. So here is what you do, you buy a termlab db meter, you install both setups and meter both. setups, whichever one is louder you keep, and then you just answered your own question.
