dsw422 Posted September 20, 2016 Report Posted September 20, 2016 Hey guys.. I just got a new to me surround system. It's a Sony STR-K740P.. all i had to do was unhook my old surround reciever and speakers then rehook it up.. only difference this time, I now have 2 subwoofers since I kept my old subwoofer. The old sub is a kicker powered by a plate amp and is directly behind the tv so the rca cable is only like 3 feet long. The other sub is across the room about 15 feet of rca cable away. It runs directly next to the right surround speaker wire.. Problem is, the new sub is playing almost all the same notes the speakers play. Is this because the rca is next to the speaker wire? The rca cable I am using is very thick (about 3/8 inch). Any ideas on what the problem may be is appreciated.. thanks 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
Krakin Posted September 20, 2016 Report Posted September 20, 2016 What is the RCA plugged into? There should nowhere enough current from one RCA to interfere with another, never mind if it did it should be canceled out if it's a twisted pair or has simple noise filtering in the amp. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
dsw422 Posted September 20, 2016 Author Report Posted September 20, 2016 What is the RCA plugged into? There should nowhere enough current from one RCA to interfere with another, never mind if it did it should be canceled out if it's a twisted pair or has simple noise filtering in the amp. The rca is a single cable that starts at the reciever that I used a y cable to split so I could run both subs. The rca is then run from the y to the sub. Here is the long run cable I am using.. Mediabridge ULTRA Series Subwoofer Cable (15 Feet) - Dual Shielded with Gold Plated RCA to RCA Connectors - Black https://www.amazon.com/dp/B003FVYXY0/ref=cm_sw_r_other_apa_DhA4xb25SCKRA 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
Triticum Agricolam Posted September 20, 2016 Report Posted September 20, 2016 Try temporarily moving one or the other cables so there is at least a foot of space between them and see if that fixes it. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
dsw422 Posted September 20, 2016 Author Report Posted September 20, 2016 Try temporarily moving one or the other cables so there is at least a foot of space between them and see if that fixes it. Just tried that and nothing has changed.. 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
Triticum Agricolam Posted September 20, 2016 Report Posted September 20, 2016 Probably not a cable interference issue then. Time to try isolating the problem. I'd unplug everything except the offending subwoofer and see if the problem still exists. If it's gone start plugging stuff back in. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ShadeTreeMechanic Posted September 20, 2016 Report Posted September 20, 2016 Sounds like your old sub has a cross over built in or the cross over point is lower. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
dsw422 Posted September 20, 2016 Author Report Posted September 20, 2016 Thanks for the help guys.. I unplugged everything except the sub and it still did it.. so it seems ShadeTreeMechanic is right that it has a different crossover point.. Is there a way I could lower it? I also just found out that my front channel speakers aren't playing.. I'm gonna open up my reciever to see if anything is burnt up inside. What else should I look for when trying to determine y those channels aren't playing? 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
ShadeTreeMechanic Posted September 21, 2016 Report Posted September 21, 2016 Does the old sub plate amp have another sub output on it? Maybe the front speakers are turned off somehow? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Triticum Agricolam Posted September 21, 2016 Report Posted September 21, 2016 So you had the subs connected through a Y splitter to the sub out on your receiver and they are getting a full range signal? Weird. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
