Jessica Posted October 9, 2016 Report Posted October 9, 2016 if you are gonna use screws, pre drill with a small bit so the wood doesnt split Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
ModestDb Posted October 9, 2016 Author Report Posted October 9, 2016 I measured and the port width is equal from the opening all the way back to where the extension ends. Must just be the photo angle. It's 2.75" wide. 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
ModestDb Posted October 9, 2016 Author Report Posted October 9, 2016 Strangeduck...a few posts up when I said I was predrilling holes thats what I meant. In case you thought I meant I predrilled the speaker screw holes. I'll predrill those too but sometime later today. 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
Jessica Posted October 9, 2016 Report Posted October 9, 2016 well your baffle is split so thats why i said that. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
ModestDb Posted October 9, 2016 Author Report Posted October 9, 2016 well your baffle is split so thats why i said that. correct. Soon as I put the first screw in, it split and then I remembered I need to predrill. 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
ShadeTreeMechanic Posted October 9, 2016 Report Posted October 9, 2016 It also might help to keep the screws away from the corners. You really only need enough screws to hold it in place until the glue dries. Some people only use glue and clamps. I like the progress. Box is looking good. I know it will sound good, Joe x is the man. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
ModestDb Posted October 9, 2016 Author Report Posted October 9, 2016 It also might help to keep the screws away from the corners. You really only need enough screws to hold it in place until the glue dries. Some people only use glue and clamps. I like the progress. Box is looking good. I know it will sound good, Joe x is the man. Yeah I'm only using 3 screws per long panel and 2 screws for the short ones. I just started out too close to edges unfortunately. I'm keeping about 4 inches from any corner or edges now. Thanks for the approval on progress! This is my first real box build. 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
ModestDb Posted October 9, 2016 Author Report Posted October 9, 2016 update right now 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
ModestDb Posted October 9, 2016 Author Report Posted October 9, 2016 almost done. Need some 2" holes for terminal cups now. 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
Triticum Agricolam Posted October 9, 2016 Report Posted October 9, 2016 Looking good! "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
