I'm adding a second RF T1500 and I'm not sure what I need to do to get the remote bass knob to work for both amps. There's no place for a sync cable, no master/slave, just rca in/outs.
I'm wondering if I have the remote connected to the first amp, will it automatically control the second amp through the rca outs? Or should i splice in a second cable and connect both amps that way?
Here's what the amp looks like... Anybody have any suggestions?
emat i dont think darvex will give you a discount for selling their products on the site : )~ good try tho. I still thin BFB should sell them and get a RF T3K
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
:lol: :lol: :lol: :lol:
SonicElectronix has that same thing for 95 cents cheaper, although, with the forum discount, it's cheaper on Darvex. :P
Its not possible with those.
You will need to buy an after market piece.
I can't even get a wireing diagram from them to build a device.
At least with the old BDs you could buy the RFC3215
Edited by ISO
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
It should control both amps when connected to 1. best bet would be to ether call Rockford or email them. They are usually pretty quick with there email response.
Team Deadly Hertz
Thanks, that looks like it would do the job but running another set of cables is easier said than done at this point. Will keep that in mind when I rebuild everything in the fall!
You're already running a set of RCA's from the head-unit to the amps, right?
Hook that unit up on the dash, plug one end into the head-unit, other end goes to the RCA cable that runs to your amps.
At your amps, to hook the 2nd amp up, run an RCA cable from the output on the first amp to the input on the 2nd amp.
Set the gains with that knob at full also.
