dsw422 Posted October 7, 2016 Report Posted October 7, 2016 Hey guys.. what size fuses should I get for a CT sounds 3000.1.. 1/0 power wire coming from battery going to both sub amp and a small highs amp.. and how many fuses will I need? The sub amp is dual input, so will I need 2 fuses for that and 1 for the highsub amp.. Thanks for the amp 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
06RTCharger Posted October 8, 2016 Report Posted October 8, 2016 http://www.stevemeadedesigns.com/board/topic/1005-wirefuse-guide/page-5#entry1291247 This is a post here about fusing wires. The general idea is that you should fuse for ur specific wire size. And ur amp should have its own fuse/fuses plugged directly into it.
3vil Posted October 8, 2016 Report Posted October 8, 2016 You'll find that a lot of amps don't come with onboard fusing
dsw422 Posted October 8, 2016 Author Report Posted October 8, 2016 I kno how to judge wire size and fuse ratings.. I'm trying to figure out what size fuse the ct3000.1 needs since there is no on board fuse and don't have the manual.. 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
SnowDrifter Posted October 8, 2016 Report Posted October 8, 2016 300a ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
dsw422 Posted October 8, 2016 Author Report Posted October 8, 2016 300a So is that 150 per input? 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
SnowDrifter Posted October 8, 2016 Report Posted October 8, 2016 300a So is that 150 per input? Provided you're using OFC wire instead of CCA: 00 awg 400 amps 0 awg 325 amps 1 awg 250 amps 2 awg 200 amps 4 awg 125 amps 6 awg 80 amps 8 awg 50 amps 10 awg 30 amps 12 awg 20 amps 14 awg 15 amps 16 awg 7.5 amps If you have CCA / aluminum wire knock about 30% off the amperage for the fuse ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
