ShadeTreeMechanic Posted October 11, 2016 Report Posted October 11, 2016 Once upon a time there were groups that actually made songs with musical instruments too. Lol I know what you mean. Some old songs could be freshened up with a new bass line. Where do you get this software from? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
bolanorthhighlands Posted October 12, 2016 Report Posted October 12, 2016 Once upon a time there were groups that actually made songs with musical instruments too. Lol I know what you mean. Some old songs could be freshened up with a new bass line. Where do you get this software from? free http://www.audacityteam.org/ My 2002 Kia Spectra LS My YouTube Channel
Bayuk89 Posted October 12, 2016 Author Report Posted October 12, 2016 Shadetree- When you download audacity, make sure you download the plugins too. Then when you install and open the program, go in the setting and install/enable all the plugins. If you need help you can PM me
ShadeTreeMechanic Posted October 12, 2016 Report Posted October 12, 2016 Thanks man, I will check it out this weekend when I get home. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
