Well i bought a cheap amp to power my DD 9515 for now and i got everything hooked up and i turned my car on and no power to the amp.
I know the Positive is getting power and at the first the Negative sparked so i knew it worked and now it wont even spark if i ground it. the amp itself has no fuse. is there a way to bypass the Remote wire to see if thats why it wont turn on or did i fry my amp when the ground sparked?
oh the amp is a SoundStorm 4000.1 ( i know its not the best gotta save more money )
you can hook up your remote wire to an ACC line instead and see if that works....
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Is it possible to cook an amp that doesn't have a fuse in the amp itself if you have it all hooked up and you put the ground to the car from the amp and it sparks.
Ive seen sparks from a ground point and not frying an amp. that alone doesnt mean its done.
Edited by mbdblue
I don't think so, That happened to me awhile back when i was installing an amp without its own fuse. Try a diff. amp
Derp.
Ok because it sparked at first and now it wont spark so i was like UH OH but I'm gonna take it to work tomorrow and hook it up to a friends system and see if he can turn it on with his then i know its ok and its my car not the amp (cross's fingers - doesn't wanna spend more money)
does your amp cost more than the car lol?
