BEEKAY Posted October 8, 2016 Report Share Posted October 8, 2016 So I'm building a cpillar wall for my 2 Team AA 18s. The power for the Teams will be 2 Ampere 5ks. I have the shell pretty much built and it's around 28 cubic feet. I'm wondering what kind of design you guys would do with the given space? My music preference is 20-40hz however I rarely play anything higher than around 37. Any help is much appreciated. Shell Measurements: 47.5 wide 27.5 deep 40 tall Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted October 8, 2016 Report Share Posted October 8, 2016 You built the shell without designing the wall first? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
MADVIBES Posted October 8, 2016 Report Share Posted October 8, 2016 in your c pillar wall is there a row of seats directly in front of the enclosure? DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz Link to comment Share on other sites More sharing options...
BEEKAY Posted October 8, 2016 Author Report Share Posted October 8, 2016 in your c pillar wall is there a row of seats directly in front of the enclosure? I have captain chairs in the back. Link to comment Share on other sites More sharing options...
BEEKAY Posted October 8, 2016 Author Report Share Posted October 8, 2016 You built the shell without designing the wall first? Yup. Link to comment Share on other sites More sharing options...
mrd6 Posted October 10, 2016 Report Share Posted October 10, 2016 Pictures would help a lot. Are those internal dimensions? My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL Link to comment Share on other sites More sharing options...
mrd6 Posted October 10, 2016 Report Share Posted October 10, 2016 With that much space, id probably design a 6th order band pass. However, if that's out of your experience level, a standard ported box tuned ~25hz should play your 20-40hz range well. My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL Link to comment Share on other sites More sharing options...
notorious97200 Posted October 10, 2016 Report Share Posted October 10, 2016 "I rarely play anything higher than around 37." : what kind of music are you listening to ? A low tuned ported box should do it for you. I'm always afraid of such monstrous subs in sealed chambers. I feel like you need to be very careful using those 4th order bandpass boxes on Team subs : got to watch, check, smell, everytime ! A 6th order bandpass would make me worry way less, but it's harder to design right. black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a 2.6 ft3 ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area. Link to comment Share on other sites More sharing options...
BEEKAY Posted October 10, 2016 Author Report Share Posted October 10, 2016 "I rarely play anything higher than around 37." : what kind of music are you listening to ? A low tuned ported box should do it for you. I'm always afraid of such monstrous subs in sealed chambers. I feel like you need to be very careful using those 4th order bandpass boxes on Team subs : got to watch, check, smell, everytime ! A 6th order bandpass would make me worry way less, but it's harder to design right. I really only listen to slowed music. Very rarely play any normal music, yes I'm weird like that. From everything I have read it seems like ported or 6th order is my best bet. Thanks for the input guys. Link to comment Share on other sites More sharing options...
BEEKAY Posted October 10, 2016 Author Report Share Posted October 10, 2016 With that much space, id probably design a 6th order band pass. However, if that's out of your experience level, a standard ported box tuned ~25hz should play your 20-40hz range well. Yes those are internal dimensions. I'll get some pics up here in a few. Link to comment Share on other sites More sharing options...
