MrSkippyJ Posted October 10, 2016 Report Posted October 10, 2016 I give up. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Jessica Posted October 10, 2016 Report Posted October 10, 2016 i see you are having issues with output. I must say there are many factors we are not aware of. Loudness is a thing of opinion and cant be quantified regularly. Maybe your carriage is not forthcoming of efficiency. Maybe your enclosure is lacking quality. Very tough to diagnose from afar. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Soccerballzs Posted October 11, 2016 Report Posted October 11, 2016 your eq is flat boost your lower settings on eq. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Jivko Posted October 11, 2016 Author Report Posted October 11, 2016 The head unit's 5-band EQ (80Hz, 250Hz, 800Hz, 2.5kHz, 8kHz) from +/-6dB
Jivko Posted October 13, 2016 Author Report Posted October 13, 2016 Also to say that I love to listen to music on low volume 30-40 of 62 max
Jivko Posted October 14, 2016 Author Report Posted October 14, 2016 if I use bass boost remote control: level 0 dB to 18 dB (Bass Boost Frequency: 50 Hz), today tried bass boost and sound better, if I use bass boost instead loudness, whether will be problem?
andru Posted October 15, 2016 Report Posted October 15, 2016 the problem with bass boost is that if it's set up right you will hit hard at 50hz and not too many other notes. If it's set up wrong it's easy to clip and eventually destroy your subs. take a look at the smd tool map, there might be someone close to you that's willing to help
Jivko Posted October 18, 2016 Author Report Posted October 18, 2016 I'm still not handle any suggestions?
ckeeler11 Posted October 21, 2016 Report Posted October 21, 2016 The head unit's 5-band EQ (80Hz, 250Hz, 800Hz, 2.5kHz, 8kHz) from +/-6dB turn up the 80 hz see how you like it.
