crownvictoria31 Posted October 17, 2016 Author Report Share Posted October 17, 2016 Im talking about the level on the amp. If turned to zero, i thought theres not suppose to be sound? Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted October 17, 2016 Report Share Posted October 17, 2016 If you turn it clockwise, you are turning it up. If you turn it counter clockwise, you are turning it down. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
crownvictoria31 Posted October 17, 2016 Author Report Share Posted October 17, 2016 Correct, right now i have it counter clock wise all the way down to zero and radio at 15 and theres a nice amount of music still being herd. Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted October 17, 2016 Report Share Posted October 17, 2016 Because the radio is at 15, Turn it to 0, and no noise will be heard. The gain is not a volume knob, you can get full output from an amp with little to no gain if the input voltage is high enough. Find someone that actually has a clue what they are doing and have them help you set it up before you wreck all your gear. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted October 17, 2016 Report Share Posted October 17, 2016 Im talking about the level on the amp. If turned to zero, i thought theres not suppose to be sound? Not even close. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
crownvictoria31 Posted October 17, 2016 Author Report Share Posted October 17, 2016 Because the radio is at 15, Turn it to 0, and no noise will be heard. The gain is not a volume knob, you can get full output from an amp with little to no gain if the input voltage is high enough. Find someone that actually has a clue what they are doing and have them help you set it up before you wreck all your gear. Thats why im here asking for help and educating myself. Ive delt with small projects simple 2 and 4 channels amps. Never had an issue. So your saying that my lanzer amp is receiveing to much input voltage? How can i check this? I have it hooked up to 1/0 gauge power wire directly from the battery and 1/0 gauge ground wire to chassis. Remote lead is from a turn on relay. I have 2 fuses before the amp at 250 each. One is on the engine bay right after the battery and one in the trunk right before the amp. Any help? Link to comment Share on other sites More sharing options...
3vil Posted October 17, 2016 Report Share Posted October 17, 2016 Input voltage from the headunit, not the battery dude. Turn your headunit down to 0, did the noise go away? Link to comment Share on other sites More sharing options...
crownvictoria31 Posted October 17, 2016 Author Report Share Posted October 17, 2016 Input voltage from the headunit, not the battery dude. Turn your headunit down to 0, did the noise go away? I will have to check tomorrow but i think it does. Link to comment Share on other sites More sharing options...
crownvictoria31 Posted October 17, 2016 Author Report Share Posted October 17, 2016 But to have an idea when i check this out tomorrow, if when i lower the radio to 0 and there is no sound, then that means is all good? What about if there is sound after that? Link to comment Share on other sites More sharing options...
crownvictoria31 Posted October 17, 2016 Author Report Share Posted October 17, 2016 ok so I went ahead amd unplugged the RCA from the lanzer amp and installed a new set of rca which is going straight to my mp3. Noticed that even by bypassing the input signal from the radio, im still getting static and poping when turning on the mp3 and turning it off. Does this indicate that the radio is not at fault? Link to comment Share on other sites More sharing options...
