matching gains on two amps
98crewcab
just double checking, I have 2 separate amps powering 4 10's. all in a shared enclosure. I dont have a DD1 yet, so not questioning the gain set (set pretty low) just want them to match (worried that if 2 subs are running at a different power level then the other 2, may damage subs?)
So i ran a 40hz signal and tested the voltage at a mid volume. At first, was a bit off. adjusted the gains until both amps threw the same reading at the terminals......
is this a safe asumption? that these 2 amps are close enough until I can get my hands on a dd1?
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
That's basically what you would do with a dd1. With a dd1 you would set them both clean and then measure voltage and turn the higher one down to match the lower one.
Pioneer 80PRS
awesome! thank you
7" BDS HC lift kit
? what is a cc1?
7" BDS HC lift kit
