Component set impedance reading higher at amp?
tbeats
For one you're measuring the DC resistance. First of the speakers and X-over and then with the addition of the speaker wires. Not to mention the resistance of your DMM's leads. They're all part of the equation. A DMM cannot measure impedance. Impedance changes with frequency. Resistance does not.
Just clearly out of curiosity, with the op's first post ... How do you know what setting the op is using when testing his equipment here ???
Also, when checking for an ohm load ... How can you have a speaker playing frequencies while checking for an ohm load ???
did you check the wire once it was hooked to the amplifier or before hooked to the amplifier?
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
  • Who's Online   0 Members, 0 Anonymous, 2157 Guests (See full list)
