Splitting high-level input to two amps?
Hey folks. First post here and I love the forum. I am trying to find out if I can run a high-level input from my factory head-unit to two separate amps (i.e. put a T in the head-unit output and run each to a small amp).
I have a Jeep Wrangler JK, and have the top down/doors off a lot. I need to keep the cheap ugly OEM radio for anti-theft reasons. The OEM radio is TERRIBLE, but I am stuck with trying to polish a turd. I also can't have a sub in the back, or someone could just reach in and walk away with it. Everything will look stock when I am done with it.
My plan is have:
2x 3.5" speakers in dash.
2x 5.25" subwoofers in the sealed lower dash pods.
2x 6.5" coaxials in sound bar above my head.
2x bass-shakers in the seats.
and 2x JL HX 280/4 amplifiers hidden under the dash
I need cross overs on each of them, so this is why I need two separate 4-channel amps with high-level inputs.
Thanks for the help!
Why not use a processor? Most are 8 channel out (which is what you would need for two 4-channel amps), and will accept your factory hi-level inputs, negating the need to split or 'T' your HU output.
I have never used one before. Do you have any recommendations for small 8 line processors? Space is the biggest crunch since I have to keep everything hidden.
Are you saying that I could send my 4 high-level outputs to the processor (from the HU), and get out 8 optimized low-level outputs (going to amps)?
Yes, you can do that.
There are a lot out there. Rockford fosgate 3.sixty
Ampere audio
JL
Audison
Helix
Mosconi
Zapco
And a lot more. Just do a search for 8 channel car audio DSP's, and find the one right for you
  • Who's Online   0 Members, 0 Anonymous, 1134 Guests (See full list)
