I have seen people sealing the holes with abs plastic, metal and other materials to really seal the door. Is the necessary or could I just trust the actually deadener itself to seal it?
-2004 Ford explorer
-Pioneer Deh-80prs HU
-4 Rockford Fosgate R1683
-2 Rockford Fosgate P1S4-12 wired to 2ohms
-1 Rockford Fosgate Prime R500-1
-I know it's very basic...
ABS plastic will shatter if you're putting out some serious air. If you have a daily system then plastic will work just fine. If not then a piece of steel is best, just bring it to a metal shop and have them cut the pieces you need and then bolt them in place.
Every project is different and every installer has different goals. If you cover those holes you are essentially creating an enclosure for your door speakers, which will create more mid bass, but also can create too much pressure build up. I think most of the installers I have seen use the Luxury Liner Pro to seal the holes, as the person above says, if you use the butyl you'll have sticky butyl over the hole with nothing for it to stick to and it could get pushed around a bit by the air pressure and touch something you don't want it touching so be careful with that. Here is a good video of Mark from Car Audio Fabrication using this type of method. CAF Increase Mid Bass
