I'm not worried about the epoxy, even though it's thick foil it's still foil. You can pretty easily cut that shit with a box cutter. The foil can very possibly tear. It would have to pull away from the butyl andhesice stuff too but it's just a bad idea. And what's the point? Why not just mount them the normal way, I must have missed this somewhere.
I do agree with you though, it probably won't go anywhere. Just seems like a dumb idea.
Edited by MrSkippyJ
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
No way in hell I would trust that. You mean no screws to actually mount the spacers right?
Yes no screws for that amp under the front seat. I dont think i need extreme strength to stop an amp from moving around under a seat. Im not a racer or a drifter lol. There shouldnt be much force moving an amp thats layed flat on the floor of the car. If i get in some kind of an accident, i dont think id be worried about an amp.
It might be a dumb idea. Im very new to this. Reason for me not using screws is im too worried about screwing into the floor where i cant tell whats under it. I looked under the car and theres stuff there but what is it? Idk lol it all just looks like metal to me, i cant tell whats what under the car, only thing i can identify under there is the exhaust pipes. So i started looking for alternative techniques to mount an amp to the floor and be secure. Thats where the epoxy idea came about. I could just epoxy the bracket to the metal body, but "if" i ever decide to take that amp and mount out, i think it would be harder if it was epoxied to the actual metal. With the damplifier i could just cut out the exact shape under the bracket, and rip up the damplifer, up comes the damp and bracket..... Then just cut a new peice of damp and lay it in there...good as new. Seems reasonable to me.
What seems reasonable is if you dont have the skills to install stuff to let someone else do it, not come up with crazy ideas to install stuff.
  • Like (+1 Rep) 3
F150:
Stock :(
Processor: DSR1
Why not just get some flat bar and bend it to shape and screw it to the seat supports and mount the amp to that?
Never thought of that. Actually someone mightve mentioned doing this on my other post, i forgot about that method. Thats another great alternative i could try. Thanks man, much appreciated.
  • Like (+1 Rep) 2
Our 6.5 mil foil will not tear from the gravity, weight, and inertia (or whatever scientific stuff that may occur) from a hard brake check. Yes it does cut with a sharp blade, but it also dulls those same blades very quickly because of its thickness. I personally would not recommend this type of a mount job either. But all he asked is if epoxy will stick to the top of our foil, and our foil is painted with a primer type paint that is great for adhesion since so many other types of products are meant to be adhered to it.
