2005 Chevy Tahoe 2 Team AA 18s Cpillar 4th Order 10k
Got the top angle iron pieces bolted together and screwed in place. Since the roof has a slight slope to it, it was much harder to get the carriage bolts to line up. I had to switch to 3/8" carriage bolts instead of 1/2" ones for the top. I was also only able to get two carriage bolts on the top so I made it up with good thick coarse thread screws into the baffle.
6677E091-4E1A-44FB-A9EA-648D0A578A50_zps
This is the top angle iron piece inside of the sealed side. You can see the only 2 3/8" carriage bolts I was able to get on the top. Was a pain in the ass to bolt those in place lol.
8B932F33-4189-48D0-8E38-FE1F3887A435_zps
Getting the inside and outside of the sealed section sealed off with foil tape for temp testing again.
29832572-79CC-4C20-ADDB-9788584842ED_zps
You can see the 2 top carriage bolts a litter better in this picture. Was also fun sticking my head in the sub holes to seal the inside lol.
DBEDCA55-F892-4D87-BFC5-063349C5EC70_zps
Everything all sealed up.
E9AB1801-707D-4495-9007-82465303E610_zps
Subs mounted again
A8A5850B-94B1-4BCE-9B67-BD37D2823EE5_zps
Covering up the amp and batteries to do some foaming to fill up some blank spaces that never got taken care of.
070C8FDC-F985-4105-8CB0-71BD9DD21AC4_zps
Left some small gaps in this PL to get a foam straw in there when I first put this piece up.
BA63C8CF-C8F0-4C8B-80BA-C659A3453B2E_zps
C5F8E012-3B0A-469E-9025-1EAC948B5812_zps
Also got the back of the corners that I put steel cage and fiberglass in foamed up. This should have done been done a long time ago lol. There is much more in the truck that needs to be foamed but that will come at a later time.
6C899B2B-4F82-416F-9538-752C2FF98673_zps
E48CB82C-9B06-4875-8BBC-44B9CC1E65DE_zps
Getting the amp out to put both in. Decided to go with some 5/16" threaded rod to stack them for now. I'm sure things will be changed in the future when I start to pretty things up. This will work for now though.
7ED0B3C0-460C-46C4-A5C2-8D6605AF0618_zps
First amp in.
BFE93DAB-FDF6-4654-9C1D-DDC25A099646_zps
Getting bottom nuts measured evenly for second amp.
4F6CA315-D03F-4E6D-8829-F463B626DD6D_zps
Second amp in.
B1E032DD-9F34-4D67-BD06-5C9FBAC843FE_zps
It was a bit wobbly with that heavy ass amp on the top so I moved it down a little bit to help with the wobble. There's now about 3/4" between both amps.
F331D5EC-A4C6-4CA2-98E1-2783F7B188E0_zps
That's where I'm at right now. I'll be wiring and matching the amps tomorrow. Gonna use some normal fuse holders for now until I can get a quad SMD fuse holder sent to me to clean up the wiring. Very excited to get both amps playing, I've never played the subs on full power yet.
So unfortunately I've ran into some bad luck. Got both amps wired up which was a mission in itself. As you can see the top amp is upside down so the set screws are on the bottom and it's a very tight fit between the bottom amp and batteries. Plus the set screws for the speaker terminals are pretty much all stripped. Took me almost an hour to get just the negative speaker wire in and actually tightened down. Was a very frustrating task with all the stripped set screws and tight area. First test the top amp was going into protect right as the bass hit. I wasn't too concerned because I was having issues popping that sub with a 9 volt battery to check polarity so I figured it was a connection. All my wiring and connections were all good on the outside of the box. So I took the whole front loading wall and port off yet again and found a loose connection to the sub for that amp. Easy fix, both subs were reading a steady .5 and both popped fine with a 9 volt this time around. Put the loading wall and port back in and sealed everything up with foil tape again. Drove down the road and started to test. Got about a minute, if that into testing and started smelling electronic smoke when I had my head in the port looking at the subs. Definitely was not coil smell so I went to the back and the top amp was smoking but still playing. Turned everything off and went home and found a small burn mark on the board. The ironic part is the amp that gave the magic smoke was the amp I've been running the last couple of months. You'd think that it would have been the one sitting on my garage floor for 6 months and has been through a truck that was rolled 4 times that would have smoked lol. Funny how these car audio things work. So I wired both subs back together to one ohm and I'm jamming on my original 5k until the other can get fixed. Unfortunate but that's just how this game goes.
Wiring first amp was very easy.
0908A648-2CB7-4457-98A5-217D381E862A_zps
Second amp was much more frustrating to wire lol.
5662042B-B976-41C2-8BB6-58992F4E8DEF_zps
Yes it's an absolute mess but this was thrown together with fuse holders I just had laying around. I was going to wait until I got another SMD quad
fuse holder to wire the second amp but my impatience got the best of me yet again lol. It will all be cleaned up with a nice quad SMD fuse holder soon.
9651CEE3-501E-4D75-AD67-236E0B947E97_zps
Both amps with those pretty green lights on.
9E7ED411-0487-495A-A11A-8BECD3E6F531_zps
Now here are some pictures of the burn mark on the board. This is where the smoke was coming from and the only burn mark I can find on the board.
a1da228c-2102-4d19-83c6-e6dd491bf6cb_zps
2E26B680-5027-4973-993F-0E5E7744049A_zps
906E00E4-A154-4648-B426-F17DF2EFA9F0_zps
The sky here in Abq New Mexico was looking crazy today.
07B803FC-7646-4836-8A96-22DC49D4274B_zps
Here's a woofer flex video for you guys on one 5k obviously lol.
  • 1 month later...
Well here will be the final update to this specific build. Unfortunately this build came to end on Friday Feb 24th. I was in a rollover accident at around 50MPH, I was not at fault of this accident. Older lady pulled out to turn onto the crossing street at the intersection on a red light. I attempted to avoid the car but she kept coming and hit me into a street light which rolled the truck. I was not wearing my seat belt during this accident and was able to walk away with only a few MINOR scratches. I had someone watching over me to survive this accident without injury and I am beyond thankful for that. When I realized that I was about to get into an accident with no seatbelt I thought for sure I was dead. I thought to myself this is how it ends for me, so early. All I could think about was all the things I have left unsaid to people I care about, all the things that I haven't done yet, I thought about everything I should have done in my life. I've never had an experience like this before and its given me a completely different outlook on life and the people around me. So I ask you to do one thing for me if you read this. Go tell those people that you love and care about how much they mean to you. Give them a big hug and just hold them for a minute. You never know when that moment could be taken away from you. Life is too short to leave things unsaid and to not love the people you care about every day of your life because that's what truly matters. Now that I've got that said, this is where the story gets weirder. 2 years ago in May I was going through that same intersection and had a similar accident. The truck was rolled 3-4 times and landed 10 feet from where this Tahoe is sitting. I was wearing my seatbelt that time and survived without injury that time also. Both times were on a Friday at about the same time and involved a red car. First time all my audio equipment was able to be salvaged, this time I wasn't so lucky. Well there is my story guys, sucks to see the last 2 years of my hard work and money be ripped from me like that. But I am alive and can see and hold all my loved ones once again which is what truly matters. Have a great day everyone and be safe out there.
C3B45385-8714-4A10-856B-A9F7AB299AD1_zps
4EC075B9-8F38-48F9-BD15-ECE02B2C7E92_zps
5F0519A9-7B3B-4F7A-B520-49C5A847D7D7_zps
187B9524-99EF-4B4B-8C99-71D09E5CB5DA_zps
B1537515-AA20-434B-9FF6-3285C5898C4E_zps
C3BEBAF5-3E64-4EF3-B201-206A080C8113_zps
7CB1C105-0907-44AF-9E1F-E3B7ACA73A3D_zps
18B07132-D1AD-4CCE-A583-A9FB40DF7400_zps
F14AF75E-C02D-4235-B333-D0DCC2FF49EA_zps
B3CD5822-BBCD-4B8A-A628-841A5F43D89A_zps
1 minute ago, nkrell11 said:
Wow man glad to hear that you're ok, looks like some serious carnage inside the vehicle. Being in an accident can be an extremely scary experience.
Ya pictures don't really do the destruction justice. It was absolutely destroyed in every aspect. Thanks though man.
22 minutes ago, 2loud4uboyz said:
WOW. What a story man, same place twice. Glad your O.K. Getting close to death will open your eye's. WoW no fire no harm to you no seat belt Wow dude.
Wow is really the only thing I can say too man. Still cant wrap my head around the whole situation.
  • Who's Online   1 Member, 0 Anonymous, 1604 Guests (See full list)
