Sky high for starter/fuse box
Hey guys. Just got the itch to start changing stuff up and tinkering as I've got some frayed wires going to my starter and fuse box coming off my positive battery terminal. To me copper is copper but I wanted to make sure but I thought I would ask anyways. Is it okay/safe to run car audio wire (sky high) to the starter and fuse box rather than the stock wiring that's getting frayed and nasty looking?
Another questions that may be silly, but again I thought I would ask, would you need a fuse to the starter or to the fuse box. I do not see any fuse as of now but hey, better safe than sorry.
This is in a 98 blazer. Everything is pretty simple and easy to change out.
Thanks,
Greg
1998 chevy blazer 4 door
stock alt 105a
Battery: Autocraft Gold 75-3
Big Three in Sky High Car Audio 4ga
subs: rockford p2 12's (soon to be sundown SA 12's)
Sundown SAZ-1200d on the subs
Mids and Highs: Infinity kappa 6.5 mid in front doors and tweets in Dash
sae 50.4 for mids and highs
SMD OM-1 on the subs
As long as the current carrying capabilities of the wire you use meet or exceed that of the stock wiring, then swapping it should make no difference whether it's "car audio" wire or welding wire or replacement OEM wiring from the auto parts stores.
The only thing that would hurt from fusing those runs is having a loose connection at the fuse holders. So, as you said, better safe than sorry :good: (I would)
A lot of times the manufacturer will put a fusible link in line with the fuse box and accessory wires where they connect to the main power distribution. A fusible link looks like a piece of wire so it might not be easy to spot. You will need to keep the fusible links in the circuit.
Pioneer 80PRS
Well I thought I was good to go but now I'm not sure about the fusible link thing. How would you ever tell where it is if it looks like the wire?
stock alt 105a
The repair manual for your vehicle would show you. You might be able to google it.
Pioneer 80PRS
If there is no fuse in the oem cable you shouldnt need one in the replacement. I have replaced my main fuse block lines in both my cars with knukonceptz 4 gauge ofc and have had no issues. Just make sure you have a good solid crimp on your connectors and you use adhesive lined heat shrink. Also be carefull in changing them so you dont break anything.
  • Who's Online   1 Member, 0 Anonymous, 1935 Guests (See full list)
