Trouble Reading Enclosure Specifications
whazoo84
I can't make sense of Orion's Enclosure specifications, is it just me or are they calling for 0.056 Ft.3 of port area? Or am I just reading it wrong? I am referencing the enclosure recommendations for the XTRPRO152 which can be found at the link here: http://www.orioncaraudio.com/docs/28-xtrpro-series-subwoofers-/Linea%20XTR%20PRO%2015in.pdf
Edit: If someone can tell me what I'm getting wrong or how much port area the subs need, I can finally start on my box build that I've been waiting FOREVER to get started on.
That is for a single 4 inch port. If the box is 2.5 cubes then it will be hard to get a big enough port that still fits inside the box.
Pioneer 80PRS
The box Is 8.8 cubes without porting. I don't wanna do sealed, I'd like to do ported so I'm guessing the port would take up a large portion of that? I know previous designs that were made came to bring it to about 6 cubes nearly even. so 3 per sub.
Try using g the port calculator on car audio dot com.You just need to enter your width, height, and the Hz that you want your box tuned to and it will give you the length of your port.
Torres comes up with .06 port "VOLUME" which is not to be confused with port area.
Port area is 12.56 in², when i used this i had it set for 3/4" and not 5/8" walls.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Can you explain port volume and area, and how do I achieve it for this sub?
For simplicity lets do this, 12x12=144 sq inches which is equal to area.
Now lets do it again but add the volume to it, 12x12x12=1728 cu. inches which is what the volume would be for a cubic foot.
The ports displacement isn't very much considering it is only a 4" tube 7.9" long.
The recommendations for port area were wrong, they used port volume instead of port area, so the next time you see something like that you can pretty much guess they used the wrong one.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
How much power are you going to be running? A single 4" port for a 15" sub is rarely a good idea, regardless of if that's what the manufacturer recommends.
Builds:
2500-5000W, as I stated above in a reply.
However, I came up with a design in Torres that I think will work, have a look:
  • Who's Online   0 Members, 0 Anonymous, 546 Guests (See full list)
