Wannabe Posted December 27, 2016 Report Posted December 27, 2016 lets say on average if you have your gains set correctly with dd or o scope,...... looking up a song on youtube or convert video into audio it will most likely be clipped ( not sayn your subs will melt ) but you have a better chance with itunes,spotify,pandora over bluetooth to give a non clipped song?? or is it typically hit or miss per song this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
ShadeTreeMechanic Posted December 27, 2016 Report Posted December 27, 2016 Hit or miss. Some songs come from the studio clipped. Different sources can play at different levels and songs can be recorded at different levels so at the end of the day it is up to the operator of the volume knob to keep the system safe. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Wannabe Posted December 27, 2016 Author Report Posted December 27, 2016 does bluetooth have complications with heavy bass? and if your bass knob has an led light (typically blue ) does this act as a clip light ( turns red when given clipped signal)?? this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
Soccerballzs Posted December 27, 2016 Report Posted December 27, 2016 Start out with a FlAC or WAV file to get the best end results. Some artist music is produced way better then others. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
RooTxBeeR Posted December 27, 2016 Report Posted December 27, 2016 In the case of obtaining music from multiple forms of sources, your best bet is to get the program Audacity and use it to check whether or not a specific file has clipping in it. I did that when I used to use the convert youtube to mp3. Get the file then check to see if it had any clipping, if it did, would look for other sources of that track. Bluetooth should not have any effect on bass heavy tracks, all it is, is a form of transportation for your signal. For the most part, most bass knobs with clip lights are not on point, I have seen some about how sundowns are pretty close but never seen any evidence to fully back that. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
Wannabe Posted December 27, 2016 Author Report Posted December 27, 2016 Thank you guys for the input, my laptop has been slow so I'm trying to get it cleaned up so I can monitor my music choices. And I'm getting a sundown amp so maybe it will aid in verifying while I'm driving to a new track but I will still check them this is my first build, i have been waiting 4-5 years to have this done 95 chevy 2 door tahoe 5.7 Xs power d3400 Singer 275amp alternator Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders Sundown SAE-1500d Mbquart onyx OA800.4 Stinger 4400 series RCAs and stinger volt meter Fi Q NEO 18, 7.5 cubes tuned 32hz Pioneer MVH-X690BS H/U Kicker CSS 6.5 comp sets in front doors Kicker KSC 4x10 coaxials in rear GTMAT and FAT MAT deadner Xenon 10k Blue HIDs
