Learned A Lesson
thats it we don't get to see any glass <_<
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
Looks good! (i have no background on anything like fiberglass but imo it looks good)
Ever think about making everything mesh in with the rear plastic so it kind of is one piece?
I want to make a box for my car! I need to watch someone do it first....
got some more resin! :D i'm gonna put another layer on the inside, let em cure overnight and start sanding and bondo tommorow. im thinking about covering them in vinyl anyone have any ideas on what type to use? cause there are some pretty wicked curves if not then some gray texture paint.
Paint will be much easier as long as you don't mind sanding enough to get rid of the Hi/low spots b4 you paint it, and make sure you primer 1st.
If you use vinyl:
1: use the stretchiest stuff you can get
2: Have a heat gun (on low) or a hairdryer handy (it will help the material stretch)
3: Use the tackiest glue you can get (industrial strength is always good) Try 3m 70 or 77...90 is a bit too "heavy" and takes a looong time to tack up..just FYI.
4: If you can use a stapler/staple gun to secure the vinyl on the backsides OF THE WOOD ONLY-DO NOT TRY TO STAPLE INTO FGLASS...this may be a no brainer for some But I have been asked this Q b4 and I'm like uhhh, not a good idea homie-the Fglass will crack.
Be sure post up lottsa pic and ask questions on this here forum as you will always have some folks here tryin to drop some tech support for ya.
~Chris.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
