My amps won't turn on! :(
Wannabe
Well everything is wired up and everything come on but my Amps I have checked all my wiring and can't find out why
my remote wire from the amps are ran to a relay
the relay is wired as so
red/ battery (and I have my volt meter hooked up to verify the relay was getting power)
black/ground
blue and white/ remote from head unit
blue/ to the 2 wires from the back
this is my first build, i have been waiting 4-5 years to have this done
95 chevy 2 door tahoe 5.7
Xs power d3400
Singer 275amp alternator
Big 3 - all Knukonceptz Kolossus Fleks 0ga/ knu Fuses an holders
Sundown SAE-1500d
Mbquart onyx OA800.4
Stinger 4400 series RCAs and stinger volt meter
Fi Q NEO 18, 7.5 cubes tuned 32hz
Pioneer MVH-X690BS H/U
Kicker CSS 6.5 comp sets in front doors
Kicker KSC 4x10 coaxials in rear
GTMAT and FAT MAT deadner
Xenon 10k Blue HIDs
Xs power d3400
Sundown SAE-1500d
Xenon 10k Blue HIDs
Yes I unhooked Rome the relay and ran the 2 remotes for the amps straight to the remote on the head unit
Xs power d3400
Sundown SAE-1500d
Xenon 10k Blue HIDs
sounds like you have a wiring issue with the relay or the relay is hooked up wrong then. Did you see the question about which relay and what wires are hooked to which pins posted earlier?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
is the fuse good? is the ground good? double check the numbers on the relay pins, i doubt they would mess up but its not impossible.
U check for power to the relay or the amp
