ThreehundredC Posted January 18, 2017 Report Posted January 18, 2017 So just picked up a skar txl. 12. Goin in a 2008 dodge charger trunk of i could get a box plan for it. That would help Greatly. I will be running a sksr 4500 amp. have wood ready to cut
ThreehundredC Posted January 18, 2017 Author Report Posted January 18, 2017 Just a basic. Slot Ported box. Please/ thanks
reedal Posted January 18, 2017 Report Posted January 18, 2017 what are your max dimensions....? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Joe X Posted January 19, 2017 Report Posted January 19, 2017 So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Enclosure Specifications: Fb = 34 Hz Vb = 3 ft^3 External Height = 14 in External Width = 34 in External Depth = 19.5 in Port Width = 3 3/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 34 x 14 Left & Right Sides = 17 1/4 x 12 1/2 Top & Bottom = 34 x 17 1/4 L Port Internal Assembly Parts: Front to Back = 13 1/2 x 12 1/2 Extension = 9 x 12 1/2
