Amps won't turn on?
So both my Amps will not turn on.  All 4 batteries are at 12.2  resting. Key off I have that voltage to my amps. Key on and radio on it drops to 8 volts, truck running it stays at 8 volts. What could cause this?
Silverado 2500hd. I just redid my grounds today. Wasn't working beforehand. I have two parrellel 4/0 from frame to distribution block and two 1/0 to bass and single 1/0 to highs
i have 12.2 from bottom of my breaker by my battery bank and 8 at the amp when key is on. I would think my grounding setup is adequate but I will have to double check. All connections at the frame are bolted and the frame was ground to shinny metal
You have a bad connection somewhere. Double check all of your connections to make sure they are clean and tight. Disconnect the turn on lead to each amp. Use a jumper to turn each one individually to see if they all do it.
Pioneer 80PRS
16 hours ago, 06RTCharger said:
 So issue is the breaker?
I don't think it has anything to do with the breaker. I'm going to go back and re clean all mounting surfaces. It absolutely has to be a bad connection somewhere. They turned on for a second today when I was driving home.
  • Who's Online   0 Members, 0 Anonymous, 1569 Guests (See full list)
