Daniels817 Posted January 25, 2017 Report Posted January 25, 2017 Making a box for 2 sp4v2 18s any idea on ports. I have a 96 2 door tahoe.
ShadeTreeMechanic Posted January 26, 2017 Report Posted January 26, 2017 It depends on the size of the box and the power you will be running. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Daniels817 Posted January 31, 2017 Author Report Posted January 31, 2017 Power 2 skar audio amps 3500.1D I'm strap them room in my tahoe I have 48in w 36in 24in high. Would it be possible to do port box subs up and port back?
Wasteland_Audio Posted January 31, 2017 Report Posted January 31, 2017 I actually had this design already drawn up from another build. It's 49" wide but you can either squeeze it in or just take an inch off the total width (I'm 99% positive it will fit at 49" tho as i've done it before).
